2538 Xem
Sáng hôm nay ngày 17/7 em có vào phần cài đặt chung trong odoo, khi click vào phần cài đặt chung có thông báo lỗi như sau:
link tài khoản của em là: e.gangviet.com
user: Ceo@gangviet.com
pass: ****
Lỗi:
  File "/opt/odoo/12/odoo/http.py", line 656, in _handle_exception
  File "/opt/odoo/12/odoo/http.py", line 314, in _handle_exception
    raise pycompat.reraise(type(exception), exception, sys.exc_info()[2])
  File "/opt/odoo/12/odoo/tools/pycompat.py", line 87, in reraise
    raise value
  File "/opt/odoo/12/odoo/http.py", line 698, in dispatch
  File "/opt/odoo/12/odoo/http.py", line 346, in _call_function
  File "/opt/odoo/12/odoo/service/model.py", line 97, in wrapper
  File "/opt/odoo/12/odoo/http.py", line 339, in checked_call
    result = self.endpoint(*a, **kw)
  File "/opt/odoo/12/odoo/http.py", line 941, in __call__
  File "/opt/odoo/12/odoo/http.py", line 519, in response_wrap
  File "/home/x1hwdnig1arc/addons/web/controllers/main.py", line 962, in call_kw
    return self._call_kw(model, method, args, kwargs)
  File "/home/x1hwdnig1arc/addons/web/controllers/main.py", line 954, in _call_kw
    return call_kw(request.env[model], method, args, kwargs)
  File "/opt/odoo/12/odoo/api.py", line 745, in call_kw
    return _call_kw_model(method, model, args, kwargs)
  File "/opt/odoo/12/odoo/api.py", line 718, in _call_kw_model
    result = method(recs, *args, **kwargs)
  File "/opt/odoo/12/odoo/models.py", line 1376, in load_views
    for [v_id, v_type] in views
  File "/opt/odoo/12/odoo/addons/base/models/res_config.py", line 395, in fields_view_get
    toolbar=toolbar, submenu=submenu)
  File "/opt/odoo/12/odoo/models.py", line 1455, in fields_view_get
    result = self._fields_view_get(view_id=view_id, view_type=view_type, toolbar=toolbar, submenu=submenu)
  File "/opt/odoo/12/odoo/models.py", line 1418, in _fields_view_get
    root_view = View.browse(view_id).read_combined(['id', 'name', 'field_parent', 'type', 'model', 'arch'])
  File "/opt/odoo/12/odoo/addons/base/models/ir_ui_view.py", line 784, in read_combined
    arch = self.apply_view_inheritance(arch_tree, root.id, self.model)
  File "/opt/odoo/12/odoo/addons/base/models/ir_ui_view.py", line 733, in apply_view_inheritance
    source = self.apply_view_inheritance(source, view_id, model, root_id=root_id)
  File "/opt/odoo/12/odoo/addons/base/models/ir_ui_view.py", line 732, in apply_view_inheritance
    source = self.apply_inheritance_specs(source, specs_tree, view_id)
  File "/opt/odoo/12/odoo/addons/base/models/ir_ui_view.py", line 710, in apply_inheritance_specs
    self.raise_view_error(_("Element '%s' cannot be located in parent view") % tag, inherit_id)
  File "/opt/odoo/12/odoo/addons/base/models/ir_ui_view.py", line 548, in raise_view_error
    raise ValueError(message)
ValueError: Thành phần '' không thể nằm trong giao diện cha
Ngữ cảnh khi lỗi:
Xem `res.config.settings.view.form.inherit.inter.company.rules
[view_id: 1936, xml_id: to_inter_company_sale_purchase_stock.res_config_settings_view_form, model: res.config.settings, parent_id: 1935]
2019-07-17
Đây là lỗi của module Inter-Company Storable Products Purchase and Sales, bên mình đã khắc phục rồi nhé.
