6606 Xem
Sau khi cài đặt xong phần mềm ERP thì nó hiện cái này
Mọi người giúp đỡ với ạ, bây giờ làm thế nào đề sử dụng được phần mềm
Your version of OpenERP is unsupported. Support & maintenance services are available here: OpenERP Entreprise.
OpenERP Server Error
Client Traceback (most recent call last):
  File "C:\Program Files\OpenERP 6.1-20120925-233125\Server\server\openerp\addons\web\common\http.py", line 180, in dispatch
  File "C:\Program Files\OpenERP 6.1-20120925-233125\Server\server\openerp\addons\web\controllers\main.py", line 498, in authenticate
  File "C:\Program Files\OpenERP 6.1-20120925-233125\Server\server\openerp\addons\web\common\session.py", line 73, in authenticate
  File "C:\Program Files\OpenERP 6.1-20120925-233125\Server\server\openerp\addons\web\common\openerplib\main.py", line 117, in proxy
  File "C:\Program Files\OpenERP 6.1-20120925-233125\Server\server\openerp\addons\web\common\http.py", line 608, in send
Server Traceback (most recent call last):
  File "C:\Program Files\OpenERP 6.1-20120925-233125\Server\server\openerp\addons\web\common\http.py", line 593, in send
  File "C:\Program Files\OpenERP 6.1-20120925-233125\Server\server\.\openerp\netsvc.py", line 360, in dispatch_rpc
  File "C:\Program Files\OpenERP 6.1-20120925-233125\Server\server\.\openerp\service\web_services.py", line 397, in dispatch
  File "C:\Program Files\OpenERP 6.1-20120925-233125\Server\server\.\openerp\service\web_services.py", line 408, in exp_authenticate
  File "C:\Program Files\OpenERP 6.1-20120925-233125\Server\server\.\openerp\pooler.py", line 50, in get_pool
  File "C:\Program Files\OpenERP 6.1-20120925-233125\Server\server\.\openerp\pooler.py", line 33, in get_db_and_pool
  File "C:\Program Files\OpenERP 6.1-20120925-233125\Server\server\.\openerp\modules\registry.py", line 180, in get
  File "C:\Program Files\OpenERP 6.1-20120925-233125\Server\server\.\openerp\modules\registry.py", line 192, in new
  File "C:\Program Files\OpenERP 6.1-20120925-233125\Server\server\.\openerp\modules\registry.py", line 66, in __init__
  File "C:\Program Files\OpenERP 6.1-20120925-233125\Server\server\.\openerp\sql_db.py", line 465, in cursor
  File "C:\Program Files\OpenERP 6.1-20120925-233125\Server\server\.\openerp\sql_db.py", line 173, in __init__
  File "C:\Program Files\OpenERP 6.1-20120925-233125\Server\server\.\openerp\sql_db.py", line 366, in _locked
  File "C:\Program Files\OpenERP 6.1-20120925-233125\Server\server\.\openerp\sql_db.py", line 421, in borrow
OperationalError: could not connect to server: Connection refused (0x0000274D/10061)
	Is the server running on host "localhost" and accepting
	TCP/IP connections on port 5432?
Dear Trường
Đây là lỗi do bạn không kết nối được với cơ sở dữ liệu. Lỗi này có thể do rất nhiều nguyên nhân, bạn thử kiểm tra lại tham số khi chạy phần mềm xem tài khoản kết nối với postgresql là tài khoản nào? Tài khoản đó có quyền truy cập vào database không? Cổng 5432 có bị chặn không?…
Cách tốt nhất để sử dụng phần mềm Odoo (OpenERP) là thông qua ERPOnline. Với ERPOnline, bạn không cần phải cài đặt gì vào máy tính của bạn và đồng nghiệp, bạn cũng không cần có máy chủ. Mọi vấn đề về kỹ thuật đã có các chuyên gia của ERPOnline lo. Bạn chỉ việc sử dụng!
Mà bạn có lý do gì khi sử dụng phiên bản 6.1 (phát hành cách đây gần 4 năm) vậy? Hiện ERPOnline đang cũng cấp Odoo phiên bản 8 với hàng nghìn tính năng mới so với phiên bản 6.1.
