3197 Xem
Odoo
  File "D:\Learn\HK7\ERP\ERP_CLASS_2015_odoo8\odoo-8.0-20150819\openerp\http.py", line 537, in _handle_exception
  File "D:\Learn\HK7\ERP\ERP_CLASS_2015_odoo8\odoo-8.0-20150819\openerp\http.py", line 574, in dispatch
  File "D:\Learn\HK7\ERP\ERP_CLASS_2015_odoo8\odoo-8.0-20150819\openerp\http.py", line 310, in _call_function
  File "D:\Learn\HK7\ERP\ERP_CLASS_2015_odoo8\odoo-8.0-20150819\openerp\service\model.py", line 113, in wrapper
  File "D:\Learn\HK7\ERP\ERP_CLASS_2015_odoo8\odoo-8.0-20150819\openerp\http.py", line 307, in checked_call
  File "D:\Learn\HK7\ERP\ERP_CLASS_2015_odoo8\odoo-8.0-20150819\openerp\http.py", line 803, in __call__
  File "D:\Learn\HK7\ERP\ERP_CLASS_2015_odoo8\odoo-8.0-20150819\openerp\http.py", line 403, in response_wrap
  File "D:\Learn\HK7\ERP\ERP_CLASS_2015_odoo8\odoo-8.0-20150819\openerp\addons\web\controllers\main.py", line 948, in call_button
  File "D:\Learn\HK7\ERP\ERP_CLASS_2015_odoo8\odoo-8.0-20150819\openerp\addons\web\controllers\main.py", line 936, in _call_kw
  File "D:\Learn\HK7\ERP\ERP_CLASS_2015_odoo8\odoo-8.0-20150819\openerp\api.py", line 241, in wrapper
  File "D:\Learn\HK7\ERP\ERP_CLASS_2015_odoo8\odoo-8.0-20150819\openerp\addons\base\module\wizard\base_module_upgrade.py", line 105, in upgrade_module
    openerp.modules.registry.RegistryManager.new(cr.dbname, update_module=True)
  File "D:\Learn\HK7\ERP\ERP_CLASS_2015_odoo8\odoo-8.0-20150819\openerp\modules\registry.py", line 370, in new
  File "D:\Learn\HK7\ERP\ERP_CLASS_2015_odoo8\odoo-8.0-20150819\openerp\modules\loading.py", line 355, in load_modules
    loaded_modules, update_module)
  File "D:\Learn\HK7\ERP\ERP_CLASS_2015_odoo8\odoo-8.0-20150819\openerp\modules\loading.py", line 255, in load_marked_modules
    loaded, processed = load_module_graph(cr, graph, progressdict, report=report, skip_modules=loaded_modules, perform_checks=perform_checks)
  File "D:\Learn\HK7\ERP\ERP_CLASS_2015_odoo8\odoo-8.0-20150819\openerp\modules\loading.py", line 176, in load_module_graph
    _load_data(cr, module_name, idref, mode, kind='data')
  File "D:\Learn\HK7\ERP\ERP_CLASS_2015_odoo8\odoo-8.0-20150819\openerp\modules\loading.py", line 118, in _load_data
    tools.convert_file(cr, module_name, filename, idref, mode, noupdate, kind, report)
  File "D:\Learn\HK7\ERP\ERP_CLASS_2015_odoo8\odoo-8.0-20150819\openerp\tools\convert.py", line 901, in convert_file
    convert_xml_import(cr, module, fp, idref, mode, noupdate, report)
  File "D:\Learn\HK7\ERP\ERP_CLASS_2015_odoo8\odoo-8.0-20150819\openerp\tools\convert.py", line 987, in convert_xml_import
    obj.parse(doc.getroot(), mode=mode)
  File "D:\Learn\HK7\ERP\ERP_CLASS_2015_odoo8\odoo-8.0-20150819\openerp\tools\convert.py", line 853, in parse
    self._tags[rec.tag](self.cr, rec, n, mode=mode)
  File "D:\Learn\HK7\ERP\ERP_CLASS_2015_odoo8\odoo-8.0-20150819\openerp\tools\convert.py", line 763, in _tag_record
    id = self.pool['ir.model.data']._update(cr, self.uid, rec_model, self.module, res, rec_id or False, not self.isnoupdate(data_node), noupdate=self.isnoupdate(data_node), mode=self.mode, context=rec_context )
  File "D:\Learn\HK7\ERP\ERP_CLASS_2015_odoo8\odoo-8.0-20150819\openerp\addons\base\ir\ir_model.py", line 1077, in _update
    res_id = model_obj.create(cr, uid, values, context=context)
  File "D:\Learn\HK7\ERP\ERP_CLASS_2015_odoo8\odoo-8.0-20150819\openerp\addons\base\ir\ir_ui_view.py", line 264, in create
    context=context)
  File "D:\Learn\HK7\ERP\ERP_CLASS_2015_odoo8\odoo-8.0-20150819\openerp\api.py", line 336, in old_api
    result = method(recs, *args, **kwargs)
  File "D:\Learn\HK7\ERP\ERP_CLASS_2015_odoo8\odoo-8.0-20150819\openerp\models.py", line 4078, in create
    record = self.browse(self._create(old_vals))
  File "D:\Learn\HK7\ERP\ERP_CLASS_2015_odoo8\odoo-8.0-20150819\openerp\api.py", line 239, in wrapper
    return new_api(self, *args, **kwargs)
  File "D:\Learn\HK7\ERP\ERP_CLASS_2015_odoo8\odoo-8.0-20150819\openerp\api.py", line 463, in new_api
    result = method(self._model, cr, uid, *args, **kwargs)
  File "D:\Learn\HK7\ERP\ERP_CLASS_2015_odoo8\odoo-8.0-20150819\openerp\models.py", line 4269, in _create
    recs._validate_fields(vals)
  File "D:\Learn\HK7\ERP\ERP_CLASS_2015_odoo8\odoo-8.0-20150819\openerp\models.py", line 1271, in _validate_fields
    raise ValidationError('\n'.join(errors))
ParseError: "ValidateError
Field(s) `arch` failed against a constraint: Invalid view definition
Error details:
Field `country` does not exist
Error context:
View `res.partner.owner.select`
[view_id: 1136, xml_id: n/a, model: res.partner, parent_id: n/a]" while parsing file:///D:/Learn/HK7/ERP/ERP_CLASS_2015_odoo8/odoo-8.0-20150819/openerp/addons/chricar_partner_parent_companies/partner_parent_companies_view.xml:331, near
<record id="view_res_partner_owner_filter" model="ir.ui.view">
            <field name="name">res.partner.owner.select</field>
            <field name="model">res.partner</field>
            <field name="type">search</field>
            <field name="arch" type="xml">
                <search string="Search Partner">
                   <group col="10" colspan="4">
                        <filter string="Customers" name="customer" icon="terp-personal" domain="[('customer','=',1)]" help="Customer Partners"/>
                        <filter string="Suppliers" name="supplier" icon="terp-personal" domain="[('supplier','=',1)]" help="Supplier Partners"/>
                        <separator orientation="vertical"/>
                        <field name="name"/>
                        <field name="country"/>
                   </group>
               </search>
            </field>
        </record>[/code]
Ok
Bạn bị nhầm lẫn, trong model res.partner không có trường country nên nó báo lỗi Field `country` does not exist là đúng rồi. Bạn sửa lại thành country_id là hết lỗi đó.
