Help
Why You Should Choose Crafito Odoo Theme?
Here are some reasons for Why You Should Choose Crafito Odoo Theme
Crafito, with its amazing list of features helps manage every portion of your Odoo store. With Crafito you can easily customize and manage menus, footer, header, product images, content, banners, shopping cart, ratings, testimonials and much more.
    Purposely made with multi-device design approach to make it compatible with all screen sizes. Crafito is a multipirpose theme that can be used for any kind of Website - from one pages sites to large ecommerce sites. No matter which industry you belong to you can use Crafito and it's design options creatively to suit your industry and preferred layout.
