Dear all,
I want to add extra cost other than the product cost, such as transportation, freight, loading, or even customs.
I want to add these costs together, and then distributed to the products or POs i choosed, in order to recalculate the price in the PO itself, and update it in inventory.
I tried to use Landed Cost but i couldn't perform such calculation, I also tried to perform it using Purchase Cost Distribution but when click on Update i got that error:
Integrity Error
The operation cannot be completed, probably due to the following:
- deletion: you may be trying to delete a record while other records still reference it
- creation/update: a mandatory field is not correctly set
[object with reference: journal_id - journal.id]
Can any one help me with this please.
Landed cost should help. But remember that your product type must be Stockable and Costing method must be Real Cost for landed cost to work properlly.
