  File "/usr/lib/python2.7/dist-packages/openerp/http.py", line 537, in _handle_exception
  File "/usr/lib/python2.7/dist-packages/openerp/http.py", line 574, in dispatch
  File "/usr/lib/python2.7/dist-packages/openerp/http.py", line 310, in _call_function
  File "/usr/lib/python2.7/dist-packages/openerp/service/model.py", line 113, in wrapper
  File "/usr/lib/python2.7/dist-packages/openerp/http.py", line 307, in checked_call
  File "/usr/lib/python2.7/dist-packages/openerp/http.py", line 803, in __call__
  File "/usr/lib/python2.7/dist-packages/openerp/http.py", line 403, in response_wrap
  File "/usr/lib/python2.7/dist-packages/openerp/addons/web/controllers/main.py", line 944, in call_kw
    return self._call_kw(model, method, args, kwargs)
  File "/usr/lib/python2.7/dist-packages/openerp/addons/web/controllers/main.py", line 936, in _call_kw
  File "/usr/lib/python2.7/dist-packages/openerp/api.py", line 241, in wrapper
  File "/usr/lib/python2.7/dist-packages/openerp/addons/email_template/wizard/mail_compose_message.py", line 54, in default_get
    res.get('model'), res.get('res_id'), context=context
  File "/usr/lib/python2.7/dist-packages/openerp/addons/email_template/wizard/mail_compose_message.py", line 104, in onchange_template_id
    values = self.generate_email_for_composer_batch(cr, uid, template_id, [res_id], context=context)[res_id]
  File "/usr/lib/python2.7/dist-packages/openerp/addons/email_template/wizard/mail_compose_message.py", line 168, in generate_email_for_composer_batch
    template_values = self.pool.get('email.template').generate_email_batch(cr, uid, template_id, res_ids, fields=fields, context=ctx)
  File "/usr/lib/python2.7/dist-packages/openerp/addons/email_template/email_template.py", line 514, in generate_email_batch
    result, format = self.pool['report'].get_pdf(cr, uid, [res_id], report_service, context=ctx), 'pdf'
  File "/usr/lib/python2.7/dist-packages/openerp/addons/report/models/report.py", line 274, in get_pdf
    paperformat, specific_paperformat_args, save_in_attachment
  File "/usr/lib/python2.7/dist-packages/openerp/addons/report/models/report.py", line 447, in _run_wkhtmltopdf
    wkhtmltopdf = [_get_wkhtmltopdf_bin()] + command_args + local_command_args
  File "/usr/lib/python2.7/dist-packages/openerp/addons/report/models/report.py", line 54, in _get_wkhtmltopdf_bin
    raise IOError
IOError
Odoo did not find wkhtmltopdf. Have you installed wkhtmltopdf on your server?
Thank you for your response,we have installed wkhtmltopdf 0.12.2.4-1 on our server now. But unfortunately, another error appeared which says :
Report (PDF)
Wkhtmltopdf failed (error code: -6). Message: The switch --header-spacing, is not support using unpatched qt, and will be ignored.The switch --header-html, is not support using unpatched qt, and will be ignored.The switch --footer-html, is not support using unpatched qt, and will be ignored.QXcbConnection: Could not connect to display
