How to validate email in odoo 9?plz send the code.
What context did you mean about "validate email in odoo 9"? Did you want to know about registration email validation?
Author Best Answer
no i mean email field validation in contacts details form.
Try the following code:
import re
from openerp.exceptions import except_orm
from openerp.tools.translate import _
Within the class, define the following method:
@api.one
@api.onchange('emai')
def  validateEmail(selfl):
        if self.email:
                if re.match("^.+\\@(\\[?)[a-zA-Z0-9\\-\\.]+\\.([a-zA-Z]{2,3}|[0-9]{1,3})(\\]?)$", email) != None:
                        return True
                else:
                        raise raise except_orm(_('Invalid Email'), _("Please enter a valid email address"))
You also need to override create and write method to call the validateEmail method.
