I like to add some fields in the warehouse so I added the class with columns in the stock.py. But it shows error. I can not find what the error is.
The error message is
File "/home/rck/Desktop/odoo-8.0/openerp/http.py", line 539, in _handle_exception return super(JsonRequest, self)._handle_exception(exception) File "/home/rck/Desktop/odoo-8.0/openerp/http.py", line 590, in dispatch return self._json_response(result) File "/home/rck/Desktop/odoo-8.0/openerp/http.py", line 528, in _json_response body = simplejson.dumps(response) File "/usr/local/lib/python2.7/dist-packages/simplejson/__init__.py", line 366, in dumps return _default_encoder.encode(obj) File "/usr/local/lib/python2.7/dist-packages/simplejson/encoder.py", line 269, in encode chunks = self.iterencode(o, _one_shot=True) File "/usr/local/lib/python2.7/dist-packages/simplejson/encoder.py", line 348, in iterencode return _iterencode(o, 0) File "/usr/local/lib/python2.7/dist-packages/simplejson/encoder.py", line 246, in default
raise TypeError(repr(o) + " is not JSON serializable")
TypeError: product.step1() is not JSON serializable
My py code in stock.py is
class product_step1(osv.osv):
_name = "product.step1"
_columns = {
'name':fields.float('Name'),
'b':fields.float('B'),
'c':fields.float('C'),
'd':fields.float('D'),
'e':fields.float('E'),
'f':fields.float('F'),
'g':fields.float('G'),
'h':fields.float('H'),
'i':fields.float('I'),
'j':fields.float('J'),
my xml code in stock_view.xml is
<record model="ir.ui.view" id="step1_tree_view">
<field name="name">step1.tree</field>
<field name="model">product.step1</field>
<field name="type">tree</field>
<field name="arch" type="xml">
<tree string="Product Details">
<field name="name"/>
<field name="b"/>
<field name="c"/>
</tree> </field> </record>
<record model="ir.ui.view" id="step1_form_view">
<field name="name">step1.form</field>
<field name="type">form</field>
<form string="Product Details">
<sheet>
<group>
<group>
<field name="b"/>
<field name="c"/>
<field name="d"/>
<field name="e"/>
</group>
<group>
<field name="f"/>
<field name="g"/>
<field name="h"/>
<field name="i"/>
<field name="j"/>
</group>
</group>
</sheet>
</form> </field> </record>
<record model="ir.actions.act_window" id="action_step1_form">
<field name="name">step1</field>
<field name="res_model">product.step1</field>
<menuitem name="Product Details" parent="menu_stock_root" id="step1_menu_mainform"/>
<menuitem name="Product Description" parent="step1_menu_mainform" id="step1_menu1_mainform" action="action_step1_form"/>
When I click the Quants and stock Moves tab in warehouse this error has been shown.
Notify me where I'm doing the mistake.
Thank you.
5591
Views
