Hey guys,
i'm trying to solve call a wizard(lets call it wiz2) out of another wizard(call this wiz1), then comfortably change the records of the wiz1-model via the model of wiz2.
My problem ist now that i get errors.. over and over, may one of you is able to help me.
here is my code so far:
The Code of the wiz1:
# -*- coding: utf-8 -*-
from openerp import models, fields, api
from openerp import exceptions
class TransferExtension(models.TransientModel):
    _inherit = 'stock.transfer_details_items'
    @api.multi
    def do_enter_serials(self):
        self.ensure_one()
        #get the reference on new model
        wizardmodel = self.env['serial.wizard']
        #create new record
        res_id = wizardmodel.create({'item_clicked':self.id})
        #Read the view_id.
        view = self.env.ref('unique_serials_v1.view_serial_wizard')
        #call the other wizard
        return {
            'name': 'Eingabe der Serialnummern',
            'type': 'ir.actions.act_window',
            'view_type': 'form',
            'view_mode': 'form',
            'res_model': 'serial.wizard',
            'res_id': res_id,
            'views': [(view.id, 'form')],
            'view_id': view.id,
            'target': 'new'
And this is the code of my wiz2
class SerialWizard(models.TransientModel):
    _name = 'serial.wizard'
    item_clicked = fields.Many2one('stock.transfer_details_items',string='Item')
so i'm getting the error:
File "/opt/odoo/openerp/http.py", line 537, in _handle_exception
File "/opt/odoo/openerp/http.py", line 588, in dispatch
return self._json_response(result)
File "/opt/odoo/openerp/http.py", line 526, in _json_response
body = simplejson.dumps(response)
File "/usr/lib/python2.7/dist-packages/simplejson/__init__.py", line 354, in dumps
return _default_encoder.encode(obj)
File "/usr/lib/python2.7/dist-packages/simplejson/encoder.py", line 262, in encode
chunks = self.iterencode(o, _one_shot=True)
File "/usr/lib/python2.7/dist-packages/simplejson/encoder.py", line 340, in iterencode
return _iterencode(o, 0)
File "/usr/lib/python2.7/dist-packages/simplejson/encoder.py", line 239, in default
raise TypeError(repr(o) + " is not JSON serializable")
TypeError: serial.wizard(7,) is not JSON serializable
and don't have any idea where the problem is.
Hope you can help me
Thanks in Advance
Pinguincommander
Hi Patrick
You can change return args:
'res_id': res_id
To
'res_id': res_id.id
And try again!
