i have developed website in odoo 10 and, I have installed recruitment module in my website, I can create new jobs from front end but when i am trying to access Recruitment/Employee menu in back end not performing any action. And can not find general settings menu in my back end too. I can not find issue why there is no any general settings menu in my module.
I have also experienced the same problem while ago. I was installing the module but due to connectivity issue, it was creating error and not showing items on the backend. So for that, I uninstalled it and then installed it properly. Afterwards, my module was working properly and I was able to manage all the menu items, database, views etc.
So you can also follow the same. Cheers
http://www.habilelabs.io/odoo/
If no custom module nor any customization affect it, you probably have data corruption. Please try on reinstalling the modules to see if it solve the problem.
Please also check error log if anything useful found for further debugging.
