and the error goes like this:
Report (PDF)
Wkhtmltopdf failed (error code: -6). Message: The switch –header-spacing, is not support using unpatched qt, and will be ignored.The switch –header-html, is not support using unpatched qt, and will be ignored.The switch –footer-html, is not support using unpatched qt, and will be ignored.QXcbConnection: Could not connect to display
Can anyone help me out with this please?
Also, there is error while printing the quotation which says it cant find wkhtmltopdf in the system.
Any kind of help would be highly appreciated. Thanks
Error In sending quotation via email
4899
Views
